Results 1 to 6 of 6
Thread: I can see through the parting lines
    Mar 2018
    Saint Johns, Florida
    Question I can see through the parting lines
    I just was looking at Steve's (GoDadGo) pics of sanding down of the parting lines and they came out so smooth and still red in color. My body is up in the rafters and when i am under it I can see right through the parting lines. Doesn't look like mine will sand down so nice. Is this normal or did I get a bod body?
    Mk4 Complete kit with IRS, IRS brakes, Power Steering, 302 mounts, 302 headers, TKO, 2 Rollbars, Leather seats,
    vintage gauges, polished stainless sidepipes, front and rear sway bars, all cutouts.
    Blueprint Engines 347 stroker; Tremec TKO 600; 3.55 IRS, 17" Bullitt wheels: 9" front 10.5" rear.
    Delivered Nov. 6, 2018. First start Aug. 11, 2019. First Go-Cart Feb. 21, 2020.
    Senior Member Garage Guy's Avatar
    Jan 2019
    Detroit MI
    Your body is fine that is just a lack of red gel coat in those areas the fiberglass is still just as thick.
    The parting line is where the mold bolts together.
    Also, had they shot the car in Clear Gelcoat, the body would be translucent.
  4. Likes Aircontroller liked this post
    Junior Member Snakely's Avatar
    Auburn, IN
    ... had they shot the car in Clear Gelcoat, the body would be translucent.
    That would be something to see!
    Mar 2018
    Oh good!
    Thanks to all you guys.
    RJD's Avatar
    Northern Virginia
    Quote Originally Posted by Snakely View Post
    ...or not see. ��
