When recently seeking a BAR Certified facility for SB100 Specialty Construction inspection in San Diego, found all closed. Does anyone know of a State approved facility?
Thanks!
Thanks!
Unless things have changed, DMV makes that appointment for you/gives you the number of the closest BAR referee.
__________________________
Try here: https://asktheref.org/
DMV may give you a list but I haven't heard of them making the appointment for you.
Good luck,
Ray
When I did mine back in 07 CHP inspector had me call DMV while I was at the CHP and they (DMV) called and I got an appointment for the BAR the same day. Don't know what to tell you Ray? Like many things with the DMV and SPCNS registration, seems like it's always changing/different.
I just went through this in San Diego. You need to get the SB 100 number from the DMV. It took me three DMV visits.... Finally had to talk to the supervisor. Lots of info on the process in other threads. The normal desk clerks just are not that familiar with the process. Once they call Sacramento and get the number, they should be able to tell you what the number is. You will get a hard copy in the mail in a couple of weeks. As soon as you have the number call the appointment number at ask the ref. I think most of the BAR places are at community colleges. My bar appt was two days later at cuyamacca college about a mile from my house. The guy there sounded like he is never busy... I had no problems with his inspection.
MK IV delivered 3/18, Gen 2 Coyote, mid shift TKO 500, IRS, all aluminum clear annodized, leather seats, F-5 preformed dash, KRC power steering, Moroso overflow tank, Russ Thompson turn signal and Drop Trunk, Breeze forward battery and lower rad support, thermotec heat/sound suppression, weatherpak at lights, Moroso cut off switch, LED lights and indicators, power and USB outlets, Stealth amp JBL speakers, seat heaters, incredible body and paint by the BAT— guardsman blue with titanium stripes.
Thanks so much for your timely response above. I do have an appointment at a BAR however is an authorized brake/light inspection required before the BAR inspection?
I live in San Marcos, the first post in my thread summarizes the steps I took to go through the complete process:
https://thefactoryfiveforum.com/show...0-Registration
Build 1: Mk4 Complete Kit #9312 Ordered 1/27/18, Delivered 3/24/18, CA SB100 Registered 9/11/19 - Gen 2 Coyote TKO600, IRS, Power Steering, Wilwood Brakes, 17" Halibrand
Build 2: Gen3 Coupe Complete Kit #309 Ordered 1/25/21, Delivered 6/9/21 - BluePrint GM 427 LS T56, IRS, AC, Power Steering
