Likes Likes:  2
Results 1 to 20 of 20
Thread: Center of the Hood vibration..
    Apr 2019
    Drove over 100xxx and it is scary! I have noticed lots of vibration at center of the hood where it is close to windshield, it this normal at speed?
    Mostafa
    San Diego
    Nope. Are your tires properly balanced? Have they been sitting on one spot for a long period of time? Is your alignment proper?
    www.myraceshop.com
    GTM solution kits
    Corvette and Race parts
    Apr 2019
    Have no steering vibration at all.
    Car was on stands for most of the build time.
    I visually see it at right where the high area of the hood is for the wipers.
    Have only driven for few second at these speed.
    I also hear some flapping noise may be in the back, not sure where from these are at speed above 60,not effect by engine RPM.
    I am sure others have had these for one reason or another just trying to get a comfortable feel about driving the car and clean these up.
    Mostafa
    Your "flapping noise".......did you reinforce the front edge of the aluminum "tray" under the radiator? If not, I would bet money that is the cause of your flapping noise...and that it's now kinked/torn in the center.
    Shane Vacek
    www.vraptorspeedworks.com
    San Diego
    This.
    www.myraceshop.com
    GTM solution kits
  6. Likes rolfer liked this post
    Apr 2019
    somehow I hear this from the back but could be from the front, my son was in the car and he said he hears it from front so hopefully this is it.
    Now the front tray by the radiator. the car rubbed on ground few time on driveway and other places, so saturday I decided to check under the car and I noticed exactly what you guys are talking about, so bought a 3/4 x1/8 thick L aluminum and placed inside and across the front edge, so that should fix that and it will be really nice if this also was the noise, what do you guys do here? I have not riveted in place yet.
    That also seems to be the lowest part of the car relative to all other aluminum underbody may be by .5 to 3/4 of inch, os this what you guys have also?
    San Diego
    I have completely redone the front radiator undertray on the FFR PDG GTM. It is all one piece and flat, along with flat bottom of the car. You will not be able to do this because you likely still have the hinged hood(?). The FFR PDG GTM has an attached to the frame front splitter and a lift off hood. The front undertray is a known issue and what you are doing is the known fix.
    www.myraceshop.com
    GTM solution kits
  9. #8
    If you sight down the very bottom surface of the chassis, the pan under the radiator is quite a bit higher than the bottom of the chassis, so that radiator pan should not be the lowest part of the car. The 1/8" thick 3/4" aluminum angle is what we normally use here to reinforce that front edge....just tuck the leading edge of the alum angle inside of the existing lip of the pan and rivet in place.
    Are you saying you already did that, or you cut the piece and never installed it?
    Shane Vacek
  10. #9
    Apr 2019
    I cut it yesterday but since I just had surgery I left installation for another day.
    Still not sure why it looks lower, but does not look close to ground so weird, this area sort of goes one way any way, rad only mounts one way, I am not there today but will check more carefully and see.
    Mostafa
  11. #10
    The front part of the chassis under the battery is angled upwards compared to the rest of the chassis....and the pan under the radiator is lower than the front of the chassis tubes, so that is probably why you were thinking the radiator pan was the lowest part.
    Shane Vacek
  12. #11
    Port Charlotte, FL
    For the center of the hood vibration, is the bulb seal on the vertical sides of the radiator up to the cowl touching the underside of hood? My aluminum required cutting to get it just right.
    Henry
  13. #12
    Apr 2019
    I am sure you are right Shane, I am just comparing to what is right behind it, I also do know is not any closer to ground as center part of the chassis but really never measure it.
    Henry, I have check these but I will check the seals again, the hole hood assembly is not great, the road I was driving on was not the smoothest road and I have seen on some video there is always vibration on any small bump on center of hood, but not as much as mine.
    Debugging one at a time, hopefully will get most of them.
    Mostafa
  14. #13
    Apr 2019
    Drove to my other GTM house, so some update.
    The tray in infact higher than the button may be by 3/4 or so, and as always shane was right, it is the angle behind that make it look like it is lower.
    Got some energy and fixed the pan it looks solid now, so now have to wait for a sunny day for a test drive for noise and hope this helped.
    Mostafa
  15. #14
    Newcastle, Wyoming
    Mostafa,
    I built a light weight 3/4" square tube frame to stiffen up the radiator pan and keep it from moving under changing air pressure under the car. Here is my solution to making the aluminum in the nose stiffer.
  16. #15
    Newcastle, Wyoming
    Did not finish typing before hitting post, brain going faster than fingers..... Hoping to make the front strong as possible and keep air moving through radiator without moving the front hood for lifting or moving or flexing with the change in air pressure moving through the front hood and insure the radiator pan in not moving as air enter the nose of the car.
  17. #16
    Apr 2019
    I think your looks good, but I am not sure if you have anything all the way at the front edge, if not I would add an 1/8 3/4 L since this front is the weakest point, after I added that it really looked solid, hope fully this was the noise.
    Center of hood, may have to try a better road first.
    Thanks for sharing. Also may be the only, have no welding tools.
    Mostafa
  18. #17
    Dec 2018
    This.
    lol I had to go fetch mine on the road after a gocart test drive.... Richard and Yvonne heard it clang on the ground and thought I had gone off the road. Since then, significantly reinforced the mounting including an angle cross brace. Still not sure it'll be strong enough for 160 on a racetrack so more to be done.
  19. #18
    Dec 2018
    Quote Originally Posted by KGTM View Post
    Mostafa
    You might be able to get rid of this if you can achieve better sealing of the hood behind the radiator and outlets at the top of the hood. If you can get all airflow out through those vents, you'll have less air/flow trying to come out at the back of the hood.
  20. #19
    Senior Member beeman's Avatar
    Indiana
    Quote Originally Posted by RR46 View Post
    Yes this is very important. But you also need to address airflow between the fascia and the radiator which is very difficult, if not impossible, with the tilting fascia/hood design. You spend $10k controlling airflow after your radiator, but unless you seal the fascia opening to the radiator, most of the air ain't going through the radiator. Which has implications for cooling as well...
    Thinking more about this, only sealing the radiator to the hood vents would exacerbate the problem since it is currently the primary way for high pressure air to exit the front of the car (assuming no wheel arch vents), other than the vents in front of the doors.
    GTM #304 LPE 525hp LS3
  21. Likes rolfer liked this post
  22. #20
    Apr 2019
    Few updates on this, The 3/4 L helped, drove it for 10 miles or so and it stayed in place, but not sure what it would do driving over 100mph for a long periods.
    The center of hood vibration, I had a video while driving and noticed it vibrates when there are road bump even small one, need to drive on clean road and check this.
