Thanks Thanks:  2
Thread: Heater Installation Question?
    Aug 2019
    Minneapolis, MN
    I am working on the Firewall and panel installation on my MK4 Roadster this weekend, at the rolling chassis point. I purchased the heater option from F5 and know that the standard install method basically eliminates the glove box. There is a comment on the firewall installation instructions about cutting the template holes for the heater prior to assembly. How can I install / route the heater components without giving up the glove box? I’m sure there is already an existing build thread on the subject- could someone help the noobie out please?
    Thanks, Jeff
    Senior Member Norm B's Avatar
    Do a google search. A coupe of threads on FFCars forum cover this problem.
    HTH
    Norm
  3. Thanks Jdauble thanked for this post
    Sep 2019
    Fredericksburg, VA
    Jdauble....
    I haven't been able to find the threads Norm suggests.
    Can you pls post if you find anything? Thanks!
    Central Lake, MI
    There are a couple options including building an extension box in the firewall that allows the heater to set more into the engine bay freeing up space for the glove box or I built a custom glove box. You can see details here:
    https://thefactoryfiveforum.com/show...l=1#post380696
    My glove box is big enough for a phone, paperwork and a wallet measuring roughly 1.25” at the top and 1.5” at the bottom.
    MKIV #9542 Complete Kit, Coyote, IRS - Delivered - 2/19/19, First start - 9/8/19, Go Cart - 9/14/19
    1965 Mustang Convertible 4v 289
    Build Thread HERE
  6. Thanks Aircontroller thanked for this post
    Likes Aircontroller liked this post
  7. #5
    Here’s what I did. Allows for a 3 inch deep glove box. If you want a defrost duct on the passenger side some kind of plenum will need to be purchased or constructed. Not enough room above the heater/glovebox for the one supplied with the heater.
    HTH
    Norm
  8. #6
    Nov 2018
    Centennial, CO
    I got it all to fit with a full glovebox, but I used the firewall forward kit and that helps to avoid building an extension box and plenum. I even got the thing in there with a fathead Coyote, though it has no room to spare.
    See my build thread at page 7 post 252
    https://thefactoryfiveforum.com/show...ter#post371340
    Let me know what questions you might have.
    Bradley
