Likes Likes:  2
Results 1 to 3 of 3
Thread: CAN-BUS Gauges w/LS Speedo and Oil Pressure
    Sep 2019
    Houston, TX
    I hope to take advantage of the Speedhut sale that ends tomorrow but I need a little more info so I don’t order the wrong gauges. Current plans are Blueprint LS and 4L70 auto. I believe the Engine ECU is GM and the Trans controller Atomic. Big questions are will the CAN-BUS Speedometer and Oil Pressure gauges work with this combo or do I need the more expensive gps Speedometer and analog Oil pressure sender/gauge?
  2. Likes Aircontroller liked this post
    Senior Member sethmark's Avatar
    Virginia International Raceway
    The oil pressure depends entirely on the computer. My early Gen III LS required usage of a oil pressure sender. The computer does not provide the PID. You’ll need to check with your computer manufacturer to find out what PIDs are available.
    33 Hot Rod #1133. LS/TKO600
    Delivered 6-17-19. Started work 7-3-19. First start 9-6-19. First drive 9-24-19
    Titled 2-28-20
    MkI.IV 2643k
    Sep 2019
    Houston, TX
    Blueprint uses the GM performance ECU w/OBD II so CAN-BUS gauges should work. I will know later!
  5. Likes Aircontroller liked this post
