Fuel level sensor gasket
Filled tank up the other day. Have a leak from somewhere on the top of the tank. Siphoned about 4 gallons and drip stopped. I suspect the fuel level sensor gasket? Lowering the tank for examination will have to wait until my lift is clear of another "project".
What is the part number for the sensor gasket? Where to get it?
Spent an hour searching online to no avail.
Thanks in advance!
Administrator
Mark Reynolds at Breeze Automotive should have them.
Henry
Try google : mustang fuel pump gasket
Factory Five supplies an "O" ring with the kit. The parts come packaged with a square shaped O ring. (that sounds wrong) FFR supplies a round shaped o ring that should be used.
FFinisher
The square shape is the correct one to use. Coat it with engine oil when installing it.
rich grsc
I use the round one. They don't leak,which is why FFR has supplied them, I have used these on .... probably 20 builds for the sender and the pickup or pump hanger.
OK, opinions are mixed.
Is the same seal used on both the level sensor and fuel pump?
davekp
Yes. You'll get mixed opinions on round vs. square. I've used both and haven't had an issue. Properly installed I think either will work. Using some lube is important. Or some recommend a very light coat of gasket sealer. Like Permatex or whatever. But probably you'll get different opinions about that too. One other thing though. Check to make sure it's not the filler tube seal that's leaking. My experience is that a failure there is more common than the two you've mentioned. Also can be affected by how much gas is in the tank.
#7750 Build Thread
Build 3: Mk4 Roadster 20th Anniversary #8674. 03 of 20. 2015 crate Coyote, 2015 IRS. Legal 04/18/2017.
#8674 Build Thread and
Video
Build 4: Gen 3 Type 65 Coupe #59. Gen 3 crate Coyote. Delivered 12/2/2017.
#59 Coupe Build Thread
I have a new one (2-1/4" dia. approx square cross-section o-ring) that I will mail to you if you wish. PM me
FFR MK4 #8317, 393 Cleveland, Lunati VooDoo solid roller, CHI 3V heads and intake, TKO 600, Std roadster seats, 8.8 3.55 diff, 17" Halibrand replica wheels, Ford "Magnetic Metallic", silver ghost stripe.
Ford in the past always used the square cross section gasket, I see now that they use the round shape, so yes, either is fine to use. If you think you will need to remove the sender or fuel pump in the future, then a lube such as oil is highly recommended, I think Permatex would be difficult to get apart, and then cleaned up?
I had square ones and they leaked. Tony Z sent me some o-rings and that fixed it. Also replaced the fill tube seal with a Ford part as edwardb suggested since the kit supplied one developed a leak.
FFR #8833 289 FIA 3-link
http://thefactoryfiveforum.com/showt...FIA-build-8833
Not a waxer
davekp
Dave,
They are both the same. As I recall when I built your car I used the square profile rings on both...but that's been 6 or 7 years ago and I can't even remember what I did last Tuesday so I could be wrong! As others have said though either will work.
