Thread: My horn again
    Senior Member Hojo's Avatar
    Apr 2018
    Springfield MA
    My horn again
    Jetfuel helped me with the horn relay connection. I got a brass encased spring loaded Riobi brush. Thanks. Now the problem is the steering column shaft. It isn’t well grounded on my car. As I turn the steering wheel the resistance to ground varies unpredictably from infinity to 12 Ohms to 0 Ohms. How do I ground the shaft?
    I had the same issue. I used the factory column with the air bag slip ring and utilized two of the wires to ground the horn relay.
    Apr 2018
    Springfield MA
    Is the “slip ring” the same thing as some call the clock spring? As you can tell, I’m easily confused.
  4. Thanks DMC7492 thanked for this post
    Likes DMC7492 liked this post
    Quote Originally Posted by Hojo View Post
    A slip ring would be a circular conductive ring with brushes conducting the electrical signal. this picture has 3 signals.
    A watch spring has wires that attach from the column to the steering wheel. they wind up when you turn the wheel. Take a look at this: https://www.motorweek.org/features/g...prings_airbags
    Yes it is the watch/clock spring! Not a slip ring. The original slip ring requires the ground magically happening through the column which did not work every time, there fore utilizing the hard wired clock spring. Thanks Bob!
    Sep 2015
    Hamersville, Ohio
    I simply added a spring loaded brush to rub against the steering shaft itself. Works great. I did have to make a retainer for the brush and screwed it to the column cover tube. I believe it was a brush originally used on a falcon steering column. Any spring loaded brush would work if you can fit it into your column.
    Harley818's Avatar
    Vancouver BC
    I just used a piece of bent copper strap against the stock (brass?) slip ring. two for redundancy. no problems.....
    Harley
    Bought 2002 Donor Jan 2014
    First Start Jan 18, 2015
    First Drive Feb 14, 2015
