Results 1 to 5 of 5
Thread: KRC power steering plug
    Senior Member bobm488's Avatar
    Sep 2014
    Temecula, Ca
    There is a black plug in the outlet connection of the KRC power steering pump, am I supposed to remove it?
    Member Jim Doak's Avatar
    Midway, Utah
    I had a KRC pump on my car (sold the car). Are you sure it's a plug and not an orifice?
    On my pump you could install fittings with different sized orifices to adjust the amount of power assist.
    Mk 1.5, 347 with Sniper EFI, T-5, 3-Link with VPM Rear Sway Bar, Power Steering with Hydraboost Brakes, Under Car Exhaust, SAI Mod, Rear Fender Flares, Dropped Trunk Mod, ... (Sold September 2019)
    Sep 2014
    Temecula, Ca
    I’m not sure what it is. It's rubber and protrudes about an 1/8" below the male connection. I have a leak at that point and I'm thinking that may be the culprit. I am afraid to tighten the connection much more.
    Mar 2017
    I have a KRC pump on my car, can you post a picture of what you are referring too?
    Build#1: MKIV Roadster #9320
    Sep 2014
    Temecula, Ca
    It was a small black plug on the outlet line, I removed it and all is well.
