Likes Likes:  2
Results 1 to 6 of 6
Thread: floppy fenders
    Jun 2018
    payson az
    floppy fenders
    has anyone come up with a good way to brace the front fenders? the fronts are so flimsy when I drive it looks like a Disney cartoon. I made braces that fit behind the tires for all 4 fenders, they work well. I'm kinda stuck on the leading edge. should I glass in some rod or just add more glass? any fender experts out there?
    Senior Member Pat Landymore's Avatar
    Dec 2018
    SW Calgary, AB
    Here’s a hint (from the assembly manual) featuring the blue truck, looking towards the back of the left side rear fender.
    It looks like some foam covered in a layer or two of woven mat ‘glass might do it.
  3. Likes LonDart liked this post
    Huntsville, Al
    I bonded some metal bracing to the front fenders to get them to settle down
    Jun 2018
    payson az
    thanks, I'm thinking maybe a combination of both. glass in some metal around the outer lip, and some of that stiff foam ( I forget the name) under the headlight area.
    Gatineau, Quebec, canada
    I bonded in some 1/4" break lines to the inside, it was easy to shape, I used filler to create a fillet and hold it temporarily then put a couple layers of glass over it to bond and seal it in permanently. Stiff and easy using materials you probably have around the shop. It also allowed me to run wiring to the outer edge as the DOT needed additional light/reflectors out there.
    Andreas
  7. Likes LonDart liked this post
  8. #6
    Jun 2018
    payson az
    that's a good idea. I like it, thanx
