Results 1 to 11 of 11
Thread: QuckJack scissor lift and our tube frame and outrider frame
    Junior Member TheDon's Avatar
    Jun 2012
    Has anyone successfully used this on our 4" tube chassis. Spacing is about 24" and it says min spacing for safety is 31.5".
    Is it safe to use the outer frame part for jacking if the load is spread out? I always use the round tubes.
    https://www.quickjack.com/car-lifts/bl-5000slx/
    Are you asking about the square tube that is in the rocker panel area under the doors? If so, yes. My old MkII has the body that stops at the bottom of that square tube instead of the MkIV style where the body wraps under that tube. When working w/ a friend w/ a MkIV it drives me crazy. On my FFR I always jack on the rocker panel tube. So easy but you can't do that on a MkIV.
    Craig,
    Like "The Don" I am looking at this lift.
    Could I possibly put a 2X8 or 2X10 across on top and use them transversely on the MK-4 since I'd be lifting from the 4" round tubes?
    I'd like to get the largest unit possible so we can use it on Baby Go-Dad's Camaro, Mrs. Go-Dad's Challenger and my Ram 1500.
    I need portability because a permanent lift won't work since I'm in a Hurricane Velocity Flood Zone.
    Again, like "The Don" I too am looking hard at the QuickJack system so any insight would be helpful.
    I don't think it would be a problem on the narrow frame as there isn't a huge amount of weight that is outside those tubes on our cars. I think the warning is more likely for typical car, and placing the Jack's too close together could cause instability. Just my thoughts on this. I installed my two-post lift in the narrow configuration and it is right at the limit of being able to position the arms on the 4" tubes.
    Jun 2012
    Thanks guys, I really want the ability to leave them on the floor and just drive over them with minor realigning to lift, I was more worried about instability if lifting from the frame tubes.
    Of course after building it for years now in the final stretch i get a lift lol.
    Senior Member FLPBFoot's Avatar
    Cape Coral, FL
    I have the quick jacks and go directly to the 4 inch tube. Very stable and not an issue. With a 4 in ride height front and 4.5 in back there is only about 1/2 to 3/4 inch clearance from frame to rubber pads on the quick jacks. Using a cross board would be problematic. When I’m going under the are I always use jack stands as my 2nd level of safety.
    Love the quick jacks.
    2nd MK4 #10639 received 3-19-23. Wife's version. Street Snake - IRS, Willwoods, no roll bars, no hood scoop, no stripes, Blue Print EFI 306 with AOD trans, and under car exhaust. Ford Eruption Green with saddle leather interior.
    1st build - Mk4 Roadster #9319, received 4-10-18. IL registration 8/6/19. Moser 8.8. 3 Link. Wilwood brakes. Blue Print 427, Holley 750, TKO 600, 0.64 OD. Paint Dec 2020. Ruby Red with Carbon Flash Black metallic stripes.
    Parker, TX
    Steve,
    I did some research after reading this thread and I just pulled the trigger on the BL-5000EXT.
    During my research I found this link from another thread that may or may not help with your question.
    https://www.youtube.com/watch?v=JyO7...ature=youtu.be
    Also, here is a post that has a couple of pictures of one in use:
    https://thefactoryfiveforum.com/show...l=1#post270285
    If you buy one from QuickJack then be sure to 'sign up' at the bottom of the QuickJack homepage to get an additional $100.
    Richard
    Nov 2019
    Hi All, does anyone have any experience using a Quickjack BL-5000SLX or BL-5000EXT on a Gen 3 65 Coupe? I'm considering purchasing one for my '18 Mustang GT and other cars but would want to make sure works for a future coupe build.
    Port Charlotte, FL
    I have used the Quickjack 7k successfully on a Gen 1, 2 , 3.1 and 4 Roadster, Gen 2 and 3 Coupe, Gen 1 and 2 Hot Rod, Gen 1 GTM and an 818 with no issue. I love it and highly recommend it.
    Thx,
    Henry
    Nov 2019
    Thanks Henry, is yours the SLX or the EXT and can you use it fore and aft rather than sideways?
    Port Charlotte, FL
    I have the 7000-SLX. I've never used it fore and aft but don't see why it wouldn't work. The only issue I see is it would be sticking out and I'd be smacking my knees on it.
    Henry
