Results 1 to 9 of 9
Thread: Wiper arm insert replacement?
    Nov 2019
    First time poster here. I just bought a mk3 from someone up in Wisconsin. I’m in Houston. I absolutely love the car and can’t wait to get through inspection/registration so I can enjoy it but have a small issue. On one of the windshield wiper arms the metal insert that slips over the post coming up from in front of the windscreen is broken. Is there a way to just get a replacement insert or is it possible to just get one wiper arm or do I need to order the full $500 assembly listed on the parts section of the ffr site? Wipers have to work to pass TX vehicle inspection. Otherwise I wouldn’t care in the slightest that the wipers on my roofless car don’t work. :-)
    It’s the metal insert that fits in here that broke.
    Any help greatly appreciated,
    Scott
    I don't know where you will find that insert, but Finish Line sells replacement arms.
    Heart of Dixie, Alabama
    Check with Speedway Motors. They sell a lot of street rod parts.
    Nov 2019
    When searching on an auto parts site what car do you search for? Sorry about the noob question. This isn’t my first performance car by any means but it is my first car not mass produced.
    X2 on the recommendation for **********. The arms are exactly the right size, have the proper connection for the wipers blades you already have, and actually are an upgrade over the arms you have. Instead of that little tab holding them in place, which is a pain and will break as you found out, uses a screw with a wedge that holds it on. Highly recommended. https://www.**********accessories.co...wiper-arm.aspx. You can buy one or both. Do it right and replace both. You won't be sorry. These are reproductions of English sports cars from the 60's. I doubt very much you'll find anything similar through the usual part store sources.
    Jax Beach, FL
    For any of the British parts, I use Moss Motors.
    They also have the same upgraded arms that ********** has.
    Mar 2018
    Maryland
    I got my replacement one from **********.
    It's pretty good because it has a screw to tighten/squeeze the arm to the nut, so if your nut is worn out, that's really helping.
    Nov 2012
    Tacoma, WA
    I got a replacement arm from FFR. Mine came off in poring rain at 45 mph. They sent me a new arm and blade for like 25 dollars plus a lot for shipping lol if I remember right.
    Dec 2012
    Houston, Texas
    Hi, Scott. I live in Houston Heights and can loan you a working wiper off my car to get you through inspection.
    PM me or text at 949-412-9174.
    Phil
    Phil: FFR 3121, Frame #2050, Mk 1.5, built 2002, 1991 donor with Blueprint 302 long block and 1993 Cobra intake, BBK 70mm T/B, no smog, power steering, T-5 and 3.55 rear.
  10. Likes Joel Hauser liked this post
