Thread: Help with roll bar rings
Hybrid View
    Senior Member TomH33's Avatar
    Nov 2016
    Parker,CO
    Has anyone found some kind of decorative ring for for their bar. I am installing my roll bar hopefully for the last time.
    After putting a niice foam cover and Naugahyde over the back, I am looking for hole covers that match the 33HR roll bar diameter. I would like Crome covers that I see on a lot of the M4 roadster. This will also cover some minor flaws around the trim of the naugahyde. I have searched the net but can’t seem to find the right word to call these rings. I though Speedway but I still couldn’t find any.
    Anyone know where I can find these, I would be grateful.
    TomH33
    wallace18's Avatar
    Trenton, Florida
    Because of the angle the waterfall is IMO you will have to make your own or have someone make them. The MK4 rings are mounted on a fairly flat part of the body. Though the ones for the angle back part of the roll bar on the Mk4 may work with a little bending. I do not have any right now that I could check for you. Maybe someone else on the forum does. Best of luck.
    http://www.replicaparts.com/roll%20b...ing%20page.htm
    I made a set from 3000 series aluminum. They end up with a moderate radius to fit close. It forms easily. I'll polish and clear before I install.
    I made a set from 3000 series aluminum. It's the same material I build the dash inserts from. Those of you that have the KVC dash know how easily it forms. I actually beat the material into submission with a brubber hammer on the waterfall itself.They end up with a moderate radius to fit close. It forms easily. I'll polish and clear before I install.
    Aug 2013
    Gatineau, Quebec, canada
    I have ordered some grommet seals from Seals-It, they are made with a specific OD and rubber ID. I still need to see how I can paint the chrome ring Burnt Copper, so it matches the other colored detail parts. Here is the link: www.sealsit.com/product/3-grommet-seal/ just pick the "ID Hole" and choose which ID you want, I was thinking 1-1/4" so it slips tightly around the pipe. I will make sure the roll bar sits where I want it then I will remove it, slip on the seal, then slide it down to where I want it and shape the ring accordingly before fastening it. Good luck!
    Andreas
    Simi Valley, CA
    Those grommet seals look like a great idea - useful in several places. I'm going to file that one away for future reference. Thanks! Keith
