Wheel Stud / Lug nut engagement
I installed the front brakes that came with my complete kit, and my solid axle rear end I got from Fortes.
I noticed the front studs are close to flush with top of the lug nuts, but the rear studs are inset from the top of the lug nuts. Additionally, the last .25" of the studs have no threads (front and rear).
I took some measurements:
Front studs have about .790" of thread engagement
Rear studs have about .630" of thread engagement
I suspect I should swap the rear studs. Looks like it will be doable if I disassemble all the brakes to make room to hammer them out. Wanted to check with the group in case I'm overthinking it.
Thanks!
Ben
