5
83
Sethmark, thank you for your suggestions! I think you led me in the right direction. I also was looking at the way you mounted your fuel pump. I was going to do the same thing as we both have the same donor motor. I was wondering however how noisy it is and can you access it in case of failure or to change the filter? Would you or have you built an access panel? Cheers Ray
