This weeks progress! Installed fuel tank, after grinding and reworking upper welds. The mounting tabs were very uneven and could not slide the gas tank into the frame. Built a bracket that I mounted on top of the I'm guessing Gen I battery tray that holds the fuel pump and filter. Started the wiring for the computer controls and added all of the fluids and mounted the tires and wheels. Unfortunately I received one bent rear wheel and a tire that had a blemish on the bead but replacements are on the way. Mounted the drivers seat after building brackets that went through the frame rails. Cheers Ray
