I haven't spent much time posting messages on the forum but, after reviewing a number of threads, I can tell it is very helpful.
Question...I just finished installing the flexible lines and fuel pressure regulator provided by FFR in my Blueprint 347 fuel injected Roadster. The fuel pressure has a return port on the bottom side which I ran back to the fuel tank using the flexible lines provided by FFR. Is it best to hook it up this way and block off the return port on the engine fuel rail or should I use the return port on the rail and bypass the regulator (blocking off the bottom port on the regulator)? My engine should arrive next week but I am just trying to plan ahead. Thanks in advance for your help.
