Results 1 to 4 of 4
Thread: $5 steering rack cradle
    Senior Member fletch's Avatar
    Dec 2018
    Just outside ABQ, NM
    I was very unhappy with the options for the passenger side steering rack bracket. I know there are options out there, but I also like saving money when I can. Here's my $5 solution:
    It's made from a 1-1/2" pipe riser clamp. Typical usage:
    It's not pretty, but it works just fine.
    Oct 2019
    Does the OEM part not work? Looks like its about $5 too.
    Looks good Brian. This is what I ended up with.
    Beware, The brackets that mount the rack are not symmetrical on the frame. I added spacers to adjust the nose steel.
    I also added a rack extension to one end of the steering rack.
    Dec 2018
    Quote Originally Posted by c11k View Post
    By OEM, if you mean the Subaru bracket, then yes. I couldn't get that bracket to fit, mostly due to the vertical offset required to make the rack level. If you mean the FFR bracket, then also yes, at least in my case. I'm not sure I had all the original spacers and brackets since I am using an 06 rack and Bob had planned to use an 05 (I think). Whatever the case, the parts I had on hand in the kit and from the donor were unsatisfactory for me. I briefly contemplated using a 3d printed part but talked myself out of it (even though my son did a great job designing & printing it. That part was beautiful compared to my welded up job!)
    Thanks for that reminder Bob. It certainly isn't visibly off. I'll be sure to measure it before I get too much further. You included a Zero Decibel steering rack extender in the kit which I installed a few weeks (months?) ago. Another reminder that it's time to update the build thread even though it feels like little progress has been made. <sigh>
