assembled the Wilwood hats & rotors with safety wire...
You might want to revisit your lockwire spec. The lockwire should be tight enough to NOT allow a bolt to rotate. The bolt to the left could turn/loosen because the wire "between" the bolts is too losses.
Good luck in your build! Never stop asking questions. There is a wealth of information here.
