Ditto - just found I have access to a 3D printer through a friend. Can anyone supply the files for spacers with the RT turn signal so I can make few sets and pay forward or if you are done with yours send to me and I will keep the train going.... PM me for email address. Cheers!
Reason: left out info
Originally Posted by
mdutton11
Same. I'd love to print my own set if someone can pass along the files. I can even ship a set or two out if anyone needs them.
Misterfubar
Make that three of us!
Karl- -I thought I had replied to this post but apparently I did not hit send. Can you send me the CAD file? I am wil PM my email. Cheers and thanks!
I would like the files as well. Thanks in advance!
Roadster kit ordered 10/10/2021, estimated completion date of 10/1/2022.
Ok, ironically I just ordered mine and I guess I need to read the 3 pages of this thread to figure out what the 3D printed device does. Hmmm. I mean unless someone wants to give me a cliff notes version......
Ted
#10333 Complete Kit, Carbed 427w, TKX, IRS and many other upgrades
- Order Date: September 11, 2021 - 20th Anniversary of 9/11
- Delivery Day: April 1, 2022 - April Fool's Day
- First Start and Go-Kart: January 20th, 2023
- Graduation Date: July 4th, 2023 - Independence Day!!
- Legal Registration Date: October 4, 2023 - My Birthday!!
Visit my MKIV Build Thread (#10333)
It just helps keep both the hub/Russ' assembly and the quick release unit centered as you re-drill the bolt pattern (different from the Lola FFR steering wheel bolt pattern). It can be done without the jigs...
I just sent some printed ones to a Forum member yesterday.
it helps to center the steering wheel with the quick release, and the quick release with the hub that Russ Thompson modifies for his turn signal.
If you don't center them and instead drill them way off center, then the wheel would "wobble" as you rotate it.
I get it.... Might look into this as well.
Thanks for the cliff notes.
Ted
BBOMAR
Found an adapter by NRG so you don't have to cut off the back of the quick release. The part number is SRK-500BK.
Attachment 151267
For anyone wondering, if you use the spacer part from NRG (SRK-500BK), it works fine, but the only issue is that if you don't trim off that section from the part that mounts to the hub as many have done, you are basically adding an extra 3/8 inch (or whatever the thickness of that spacer is) to the depth of the steering column. This is not a problem for some folks, but if you want to maximize space in the cockpit and push the wheel toward the dash as much as you can, you will still need to cut the piece off the quick release. I was a little confused until I got the parts. But if you don't need the extra space and don't feel like cutting anything off, this stock spacer is a great option.
Darryl [dbo_texas]
MKIV #9644 (build thread) (Index)
MK4 Complete Kit | Gen2 crate Coyote | Tremec T56, 3.55 IRS | power steering | hydroboost | dual roll bars | FFR carbon fiber dash | 18" Halibrands + Wilwoods | RT drop trunk kit & turn signal | front battery mount | saddle leather Intatrim Stoneleigh seats + interior accents
NRG quick release.
I hope someone here will be able to help me. I am a disabled Vet and have a fused knee on my left leg. I should have found a local roadster to see if I could get in or out. With the FFR wheel in place, I can get in, but when it comes to getting out it takes several minutes of trying to find the way out.
I have the NRG SRK400CF and need the plastic device you all have used to help ensure concentric alignment while drilling the needed hole pattern.
I realize the events in the thread happened back in 2020, but I'm in a corner trying to find a way out.
Any help you can provide will be greatly appreciated and I am ready to pay for your time and material.
Cheers - Kobra Kermit
Kermit Pethtel
Major USAF
Retired
Kobra Kermit
NRG quick release.
Thank you for your service, I also am the same type vet U.S. Navy retired.
Capt. B
FFR Roadster Delivered 9/16/21
Forte 427 Fuel Injected with TKX Transmission
Forte's Axle
cgundermann
Just PMed you.
Thanks Chris. Problem solved. Fixture will be going back tocgunderman after the drill press and tap work.
This forum rocks.
Thanks to all who PM'd me.
Could I get a copy of the cad files to print off the jig? Alternatively, I could pay for shipping for someone’s that’s done with it and then pay it forward for the next guy. Thanks in advanced!
