I’m wondering... other than the engine and trans, are the 96 4.6 mustangs the same as the 94-95 with the 5.0? Rear end, spindles, etc?
When using SN95 parts the 1996 and up spindles are less desirable than the 1994/1995 variety. The '96+ sets the wheel out approximately 3/8" more per side which can result in tire to body clearance issues. Additionally the dogleg steering arm on '94/'95 spindles have better bump steer geometry than the straight arms on the '96 and up spindles. More than one builder has swapped out the 96 and up spindles for 94/95 or the FFR proprietary ones after completing the car... The rear end, brakes, fuel tank and pedal box are the same.
Can confirm Jeff's comments. I used a '98 Cobra donor. One go cart spin around the block convinced me I needed to exchange the straight arm 98 spindles for the dog leg, 95 spindles. All is well now!
MKIV #8740, Canadian base kit, Picked up Dec. 2015, ‘98 Cobra 4.6 l DOHC, T45 transmission, old style IRS, Art Cuesta dieted harness/Ron Francis chassis harness, go-cart July 2018.
Thanks gentlemen! I’ll keep looking!
Are you going to use the FFR spindles? If so that donor will be fine. I strongly recommend the FFR spindles. The front suspension has evolved since the beginning. Until FFR made their own spindles the best setup was 94-95 spindles plus the SAI mod. I don't think anyone is making the SAI mod any more. Whitby's was but????? If you go w/ the FFR spindles you don't need the SAI mod and you will have the best front suspension geometry possible. To somewhat offset the $, the FFR spindles do include the front bearing/hubs which are $83 each at Advance.
https://shop.advanceautoparts.com/p/...+wheel+bearing
Yes there are less expensive ones available but this is one place where you get what you pay for.
Sten,
I'm wondering why you said you'll keep looking after the spindle comment. If the donor fits your need, don't let the spindles drive you in a different direction (no pun intended).
As mentioned, you can get 94-95 spindles pretty cheap. Or the new FFR spindles too.
What are your plans for this new car? I think that is more important to determining if the '96 donor is good for you or not (not just the spindles).
Craig
I used a 1996 donor. I wish I used a later model. I believe the 96-98 engines used different, lower performance heads. I believe there are far fewer after market custom parts for 96-9 than for 98-04. In 1996 ford used the all plastic intake manifold, with the plastic coolant crossover pipe. that must be upgraded. I don't know if you can get headers for the 1996 engine anymore. also, edelbrock makes an intake manifold carb conversion kit for 99-04 mustangs; it won't work on 96-98. you can't convert 96-98 to carburetor As for the differential, I was unable to use the wide halibrand wheels without an axle and brake caliper mount mod, so I used the stock mustang wheels.
Thanks all! Got it resolved
Steno,
Jeff knows these cars better than anybody, but you may be able to simply search for wheels with a deeper offset to fit that 1996 axle.
If you are forced to go with a wider rear, just increase the offset.
Possible Front Wheel:
https://www.summitracing.com/parts/are-106a-896530
Possible Rear Wheel:
https://www.summitracing.com/parts/are-106a-816545
I'm sure you can find something with a deep enough offset to make that 1996 rear end work.
My recommendation is to find a rear wheel that works and hopefully you'll find a matching front wheel that has a workable offset too.
