Finally got my car on race scales. Anyone want to guess what it weighs? No carpet or insulation. Full taken of gas. Ls/tko
33 Hot Rod #1133. LS/TKO600
Delivered 6-17-19. Started work 7-3-19. First start 9-6-19. First drive 9-24-19
Titled 2-28-20
MkI.IV 2643k
1,950 lbs
The Hot Rod New Chassis Crazy Light As Is An Aluminum Blocked LS!
NOTE: I'm assuming you installed an all aluminum LS.
LQ9. Iron block. So it’s plus 100 over aluminum.
Titled 2-28-20
MkI.IV 2643k
2250lbs
Mine weighs 2292 and has much more steel tubing in it than yours does.
Apparently it has less than a stick of tubing more.....
Titled 2-28-20
MkI.IV 2643k
Great Thread That Was Lots Of Fun!
Thanks For Posting!
2277 - you got to remove 37lbs somehow to get it under a ton - a proper UK ton that is
I was going to try and get it down to 1933
Titled 2-28-20
MkI.IV 2643k
Seth, was that with the top on and all the windows installed?
Nah. Im a dyed in the wool roadster guy. It was roll bar, seats, mats, car cover in trunk. No paint or carpet. So I would expect to add about 30#.
Titled 2-28-20
MkI.IV 2643k
Iron 6.0 block, full 8.50 cert. cage, hell, the 92mm turbo alone weights close to 70 lbs.
