Results 1 to 11 of 11
Thread: Coyote Gen 2.5ol Coyote from summit
Hybrid View
    Nov 2019
    In need of help
    has any one tried this engine package it suppose to be plug and play
    installing in a gen three MK4 does it fit
    I'm very new at this need to start somewhere
    Summit has a ford performance part s M-9000 PMCM Ford performance Gen 2 5.ol coyote power modules Its the Engine and Transmission Combo, Coyote Power Module, Assembled, Aluminum Heads, Tremec, Ford,
    Brand:
    Ford Performance Parts
    Manufacturer's Part Number:
    M-9000-PMCM
    Part Type:
    Engine and Transmission Combos
    Product Line:
    Ford Performance Parts GEN 2 5.0L Coyote Power Modules
    Summit Racing Part Number:
    FMS-M-9000-PMCM
    UPC:
    756122003381
    Engine Assembly Style:
    Long block
    Assembled:
    Yes
    Intake Manifold Included:
    Yes
    Carburetor Included:
    No
    Throttle Body Included:
    Yes
    Cylinder Heads Included:
    Yes
    Cylinder Head Material:
    Aluminum
    Distributor Included:
    No
    Oil Pan Included:
    Yes
    Valve Covers Included:
    Yes
    Timing Cover Included:
    Yes
    Water Pump Included:
    Yes
    Harmonic Balancer Included:
    Yes
    Spark Plugs Included:
    Yes
    Spark Plug Wires Included:
    Yes
    Flexplate Included:
    No
    Flywheel Included:
    Yes
    Transmission Included:
    Yes
    Transmission Controller Included:
    No
    Torque Converter Included:
    No
    Wiring Harness Included:
    Yes
    Computer Included:
    Yes
    Quantity:
    Sold as a kit.
    In-Store Pickup:
    Choose In-store pick-up (OH, NV, GA, TX) on our web site.
    Ford Performance Parts Coyote power modules are a complete modern powertrain solution. Ford Performance Parts has assembled a complete kit to simplify the swap of the modern 5.0L Coyote engine into just about any Ford vehicle. Their Coyote power modules team the Mustang GT 435 hp Gen 2 5.0L Coyote V8 with a state-of-the-art 6R80 6-speed automatic transmission or the ultra-tough Tremec 6 speed manual; along with all of the electronics and hardware to finish the installation. They shorten the typical research and assembly processes by putting together a special package of the right parts, carefully coordinated for strong performance and refined drivability. Both the engine control pack and wiring harness are plug-and-play and streamline the conversion to a modern, electronically fuel injected, V8 high performance engine.
    Features include:
    * 2017 Mustang GT 5.0L Coyote Gen 2 engine--M-6007-M50A
    * 435 hp
    * 400+ lbs.-ft. of torque
    * 11.0:1 compression ratio
    * Aluminum block
    * Complete engine controller and wiring harness
    * Boss 302 alternator kit--M-8600-M50BALT
    * Starter and starter index plate
    * Control pack PCM and installation kit is tunable for power upgrades--M-6017-504V
    * Runs on pump gas
    * 6R80 6-speed automatic transmission with flexplate, converter and lines or Tremec 6-speed transmission with clutch assembly
    * Installation hardware
    Its exactly what you need but did you know you can just get it right through Factory five and it comes with everything you need in one neat package.
    Mike is right. Factory Five also sells a similar engine/trans combo. One thing that would be a question though is whether the Gen 2 Coyote is even available. I've heard from several sources they aren't, and if you search multiple sites where they've been available in the past, they're saying not available. That vintage Coyote ended production in 2017. The factory is only making the Gen 3 version now. Ford Performance put a supply of Gen 2's in their warehouse, but once gone that was it. Probably still some out there in various places, but I suspect that option is nearing the end. Summit shows the Gen 2 as not available. I wonder if you did order that combo from them whether they would be able to fulfill it.
    Nov 2019
    Its that dam plum hang in my face the engine and trans only for $ 13,000 and change
    I don't know were to get a good deal on both this should be turn key but the proof is in the pudding
    Its the same price at Factory Five. Call them on Monday to discuss. You wont be sorry. I have taken delivery of 3 from them.
    Folsom, CA
    or hit up mike at http://fortesparts.com
    Todd
  7. Likes Railroad liked this post
    Quote Originally Posted by toadster View Post
    For the record, I've heard from several that Mike is no longer selling the Gen 2 Coyote. He apparently can't get them any longer. Only the Gen 3. Same as what I described in my post #3. Google M-6007-M50A. That's the Ford part number for the Gen 2 Coyote. Mostly not available.
    Folsom, CA
    ah yes, good point - he is out of Gen1/2 Coyote motors...
    Todd
  10. #9
    Feb 2020
    Chicago
    what is FF pricing on a Gen 3 coyote with trans?
  11. #10
    Quote Originally Posted by jiriza84641 View Post
    508-291-3443
    Happy to help
    I think it was $16150.00 completely assembled. there might be a shipping cost as well/ Picked one up a couple weeks ago.
