Parking brack won't release on left wheel
Hello all,
Here I am again. Got the driveshaft to adapter bolt situation fixed. However, for a long time the left rear brake caliper has been sticking after using the parking brake. The little coli spring seems not strong enough to pull the cable back. I tried re-routing the cable to avoid tight bends but still the brake sticks and I have to pry the return spring.up to release the parking brake. Maybe need a new cable. Or...is there a stronger spring to overcome the friction of the cable?
Hope to hear soon,
Mk4 Complete kit with IRS, IRS brakes, Power Steering, 302 mounts, 302 headers, TKO, 2 Rollbars, Leather seats,
vintage gauges, polished stainless sidepipes, front and rear sway bars, all cutouts.
Blueprint Engines 347 stroker; Tremec TKO 600; 3.55 IRS, 17" Bullitt wheels: 9" front 10.5" rear.
Delivered Nov. 6, 2018. First start Aug. 11, 2019. First Go-Cart Feb. 21, 2020.
try removing the cable and see if it still does it. If it does you might need a new caliper. If it doesn't you need to reroute your cables or find a place to attach a return spring to that caliper.
I put a piano spring in there to pull it back. Can't take credit for the idea, but works great!
Thanks, I was thinking about such a spring. Re-routing didn't work.
I wonder if this was the same cause for the sticking?
https://thefactoryfiveforum.com/show...tiple-calipers
