Thanks Thanks:  4
Likes Likes:  5
Results 1 to 10 of 10
Thread: Mk4 w/Coyote builders. PDM mounting question
    Senior Member tbl100's Avatar
    Mar 2019
    Roseville, CA
    Hi,
    For those of you who have Mk4's with Coyote. Has anyone mounted the PDM between the firewall and the dash? Is there any compelling reason not too? Just wondering if there is any other place to put it besides on top of the PS foot box like FF shows.
    Tim
    Mk4 Complete Kit delivered 5/2019, Gen 2 Coyote, TKO 600, IRS, Wilwood F/R, Power steering, Halibrand 17” X 9” Front 17” X 10.5” Rear, Nitto NT555 G2 F/R
    I assume you mean PDB (Power Distribution Box). I don't care for that footbox location either. But I'd be a little reluctant to mount it between the firewall and dash. Depends on where and how, but it has fuses and relays that need to remain reasonably accessible. On the Coyote builds I've done, mounted it on the DS firewall. Plenty of room behind the engine. Doesn't stand out and looks like it belongs there. Easy enough to access if necessary.
    Mar 2019
    Roseville, CA
    Wow, that looks really nice. I thought of that as it seemed to be a natural place for it but I didn't think it would fit or it would be very tight and if it would be easy or not to open and close if needed. My motor is out right now and I was trying to eyeball it from photos and measure based on photos. Currently my fuel regulator is located in that position because I started with the FF instructions for running the fuel lines down the trans tunnel. I nixed that idea and ran hard lines down the PS frame but left the regulator there and ran flex fuel lines to it. I also wanted to put the cut off switch in the same place as you have it. I'll give your solution some very serious thought. Thank you. BTW, your engine bay looks really clean. Nice job.
    Feb 2018
    Frisco, TX
    I followed edwardB's lead on this one as well. I suppose it may work on the other side of the firewall if you mounted it upside down in the area about where a heater or glove box would go, and then you could reach up under the dash to open it if you needed to access the fuses inside. Any other area behind the dash is going to be completely full as it is with all the wiring. You know it works fine here with little modification to the existing harness and no interference with the motor.
    Mar 2019
    Roseville, CA
    Yes, behind the dash is pretty congested as it is. I'll nix the idea of putting it back there. Thanks for the reality check on that. I think I'll lay this all out as you guys have done and see how it goes. I like it. The modifications to my existing install would be minimal. Really just moving the regulator and shortening the fuel lines. Thanks for the feedback.
    In addition I was looking at the power cable from the battery (I have the forward mounted battery as well) and routing will be much cleaner the way you guys have it.
    Mar 2019
    Roseville, CA
    How did you mount the PDB to the firewall? Rivet nuts or drill and tap the square tube?
    Quote Originally Posted by tbl100 View Post
    There's enough meat there. I drilled and tapped. 1/4"-20 thread.
  8. Thanks tbl100 thanked for this post
    Likes tbl100 liked this post
    On a roll Al_C's Avatar
    Wheaton, IL
    I believe that where Paul mounted the PDB is the best location. That's where mine is, too. I ran bolts all the way through the 2 inch square tube to mount it. I also mounted my 250 A fuse on the firewall. The mistake I made the first time around was mounting it too close to the PDB so I couldn't get at the fuse box. So if you mount the 250 A fuse above the PDB, please ensure you leave enough room so you don't end up drilling more holes as I did.
  10. Thanks tbl100 thanked for this post
  11. #9
    Nov 2018
    Centennial, CO
    Hi,
    Tim
    I’ll add that it needs to be mounted a little bit higher if you are using the firewall forward mod.
    Bradley
  12. Thanks tbl100 thanked for this post
  13. #10
    Senior Member Fixit's Avatar
    Minneapolis 'Burbs
    PDU in FFR location
    Just as an FYI for you... here's #9365 in the early stages. The PDU is in the FFR location, but I bumped it forward a bit for heater & wiper clearance.
    John D. - Minneapolis 'Burbs
  14. Thanks tbl100 thanked for this post
    Likes tbl100, toadster liked this post
