Papa
I would recommend not using any supplied spacer tubes until you get the body where it needs to be and then if you still want to use them, trim the tubes to fit the body placement. You can also trim the rear lower edge of the trunk aluminum a bit to get the body forward.
I will look at trimming the lower edge of the trunk aluminum. Do you know how far forward is the body to the door strike tabs?
