looking for advice the gen 3 manual dies not give much detail on front inner wheel well splash guard
it looks to me that i could screw it to the fiberglass flange that is under hood without using rubber
what have others done?
Assume you're talking about the front upper splash panels that go on the underside of the hood. The manual shows using bulb seal only on the curved section where it pushes against the outside curve of the body. Also says to use silicone RTV there. But I didn't find that necessary because it wedges very tightly between the wheel well lip and the flange that's on the inner shell. Then it says to rivet the smaller section that goes forward to the inner shell flange. Which I did.
I personally added more bulb seal. I added a piece along the bottom of the section that goes forward. Found that it sealed things a little better. Comes down in the area of the hood strut. I also added bulb seal on the two sides that match up with the lower splash guard. Helps to seal things up better there too.
I don't have any specific pictures. But was able to crop this picture showing only those areas, and change the contrast enough that things are visible. Hope that helps a little. I guess the main message is install it so it does the best job of closing things up. Also, I powder coated mine and also added undercoat (UPOL Rapter like I used everywhere else) on the side that faces the tires.
I mounted mine without bulb seal to the outside of the flange. I have bulb seal betwen the upper and lower inner fenders
David W
Mkll 4874 built in 2004
It's intended to go between the wheel well lip and the flange (as I mentioned before) at the bottom corner. And then on the outside of the underhood flange going forward. There's no other way for it to go in without cutting something. I guess you could rivet the curved section to the flange instead of using bulb seal per the instructions. Not sure what the advantage would be but can't think of a reason why that wouldn't work.
the inner fenders fit with no trimming and I put them in with rivets all the way around the curved section. Bulb seal just between the upper and lower.
David W
