Thanks Thanks:  3
Likes Likes:  7
Results 1 to 21 of 21
Thread: Connecting Vintage Tach to Coyote engine
    Senior Member tbl100's Avatar
    Mar 2019
    Roseville, CA
    Coyote with Vintage gauges
    For connecting the Vintage gauge Tachometer to a Coyote engine the FF Roadster Coyote Engine installation instructions say to splice the purple COIL->TACH wire from the RF harness into the #4 cylinder coil plug wire.
    Is there another ways to hook up the Tach other than tapping into the #4 cylinder coil plug wire as instructed?
    Also, if tapping into the coil plug wire is necessary what type of connector is best to use to disconnect this wire if the engine needs to be pulled at any time in the future.
    Again, thank you for any assistance.
    Tim
    Mk4 Complete Kit delivered 5/2019, Gen 2 Coyote, TKO 600, IRS, Wilwood F/R, Power steering, Halibrand 17” X 9” Front 17” X 10.5” Rear, Nitto NT555 G2 F/R
    That's the only choice. You have to break into one of the coil-on-plug harnesses and tap the signal wire. It doesn't have to be #4. Can be any one of the eight. Pick the one that's most convenient for your wiring layout. You could add an in-line connector I guess if you wanted. I figured if that happened I'd just cut the wire and splice it back. Don't forget also you have to calibrate the tach to the ".5 pulse per rev" setting. Many forget that step and wonder why the tach doesn't work properly.
    Be glad you didn't pick Autometer gauges. (Not that they aren't nice gauges...) It too requires you to break into the harness. But in a different location and also requires a $100+ tach adapter.
  3. Thanks tbl100 thanked for this post
    Likes tbl100 liked this post
    Mar 2019
    Roseville, CA
    Thanks for the feedback and confirmation. Always appreciated.
    Raleigh NC, OIB NC
    What is the best way to physically make the connection? Am replacing my FFR base AutoMeter tach & gauges with a SpeedHut Cobra 4" tach & gauges.
    Kevin
    MKIV #8234
    On a roll Al_C's Avatar
    Wheaton, IL
    Here's one way:
    I used a female spade connector. The engine wire is crimped into one of the "loops".
  7. Thanks tbl100 thanked for this post
  8. #6
    I carefully removed a section of insulation from the Coyote coil pack signal wire. Then wrapped the new wire several times around the exposed wire and lightly soldered. Then wrapped the splice with 3M 33 electrical tape. Then replaced the engine harness insulation with the new wire pulled back and routed through the firewall to the gauge.
  9. #7
    Senior Member karlos's Avatar
    Littleton, CO
    MKIV Roadster #8641
    Complete Kit with IRS, Eaton Detroit Truetrac, 3.55 gears, Wilwood Brakes
    Ford Racing Z427 w/ Pro-M Sequential Port EFI System
    TKO 600 + McLeod Midshifter; Fast Freddie's Electro-Hydraulic power steering
    Miller Customs Bodywork & Paint
  10. Thanks tbl100 thanked for this post
    Likes Kmcallahan liked this post
  11. #8
    Quote Originally Posted by karlos View Post
    There isn't a lot of space. But that's an interesting approach. Might fit. Dug through my pictures and found I did my 20th Anniversary similar to what Al_C showed. On the Coupe (Gen 3 Coyote, which requires the same kind of connection) I just wrapped and soldered as I described before. Also, back to the OP, when looking at my pictures see that I did put a single spade connector on the wire so it could be removed in case of maintenance, engine removal, whatever. Memory fades after a couple years.
  12. #9
    Raleigh NC, OIB NC
    Thanks all. That will set me up fine.
    Kevin
    MKIV #8234
  13. #10
    Mar 2019
    Roseville, CA
    OK cool.. This is what I was planning on doing. Adding the spade lug. I plan on splicing by removing insulation, wrapping the wires, soldering then wrapping with electrical tape.
    Thanks again
    Tim
  14. #11
    Mar 2019
    Roseville, CA
    I placed the Tach wire in with the Sensor harness leg coming through the fire wall. Will this be ok? Will the Tach wire put any electrical noise on the other sensor wires and cause any interference or problems?
  15. #12
    Quote Originally Posted by tbl100 View Post
    Nope, that's fine. Did the same thing on both of my builds.
  16. #13
    Mar 2019
    Roseville, CA
    ok great, Thanks
  17. #14
    Jax Beach, FL
    OMG. My eyes hurt!
    There are plenty of 2 into one PROPER connectors out there. Piggyback terminals, scotchlock (put the wires in and click), 3 way bullets. You can do it with a weatherpack. Or if you can solder, a 3 way splice.
  18. #15
    O'Fallon, MO
    SCOTCHLOCK, who the h-ll would use a scotchlock on an auto? Turn in your card.
    Mrk III, 331 stroker, Borla stack injection, T5, 3:55 IRS, Power steering and brakes. Kleiner body & paint
  19. #16
    OMG. My eyes hurt!
    Look closely at the harness we're breaking into. It's about 1-1/2 inches long and has zero slack. It's also feeding one of the coil-on-plug modules, so obviously critical and you don't want to do anything to disturb that. Tapping a signal off to drive a tach is secondary. So peeling back a short section of insulation -- which doesn't disturb the primary wire -- and attaching the signal wire in as non-invasive way as possible is the primary goal. Any method that would cut the existing coil wire is out IMO. That rules out several of your suggestions. I'm not a fan of Scotchlok taps and haven't ever used them in my car builds. The Posi-Tap product karlos suggested is a possibility. Haven't seen that before. Otherwise, look away I guess. And definitely don't look at the Factory Five instructions.
  20. Likes GTBradley, tbl100 liked this post
  21. #17
    Nov 2018
    Centennial, CO
    Totally agree. This connection made me a little uncomfortable as the coil is important and the tach less so. I would never use a connector here as it adds weight and complexity to the coil wire. Carefully stripping back the insulation and soldering is the only way I think this should be done. It would have been nice if Ford were to supply the tach signal in a more accessible way, though.
    Bradley
  22. Likes tbl100 liked this post
  23. #18
    ...It would have been nice if Ford were to supply the tach signal in a more accessible way, though.
    Yeah, I certainly agree and have talked to a couple people at Ford Performance that I've gotten to know. I pointed out that the performance/hobby market they're selling these crate engines and control packs to are all going to have aftermarket tachs and sure would be nice to have a direct connection, like the Gen 1 control pack had. They agreed, but said there's nothing in the PCM/ODB2 for the Gen 2 and Gen 3 that is compatible with the "traditional" tach gauge feeds used by our aftermarket tachs. Which hasn't changed for decades since we pulled the signal off one side of the old style coils. Said we had no choice but to use a tach adapter, required with Autometer (and perhaps others) or go directly to a single coil on plug signal which fortunately the Speedhut gauges support.
  24. Likes GTBradley, tbl100 liked this post
  25. #19
    Jax Beach, FL
    Rated for automotive and marine. I guess you like the crimped spade lug better?
    From 3M: - https://www.anixter.com/content/dam/...nectors-br.pdf
    Choose from 35 different Scotchlok IDCs to
    meet a variety of uses, including fluorescent ballast
    installation and replacement, fixture and appliance wiring,
    automotive and marine wiring and control circuit wiring.
    There are specific ones just for automotive. 905 and 905N.
    edwarb - exactly what these are good for is where you have no slack and you don't cut the main wire.
  26. #20
    Understand. Don't use 'em. Not saying it's right or wrong. We all have our own preferences and that's one of mine. The OP asked questions about how to hook up the tach wire and I showed him how I did it. He can go another way if he wants. His choice. I'm confident with what I did, but not everything will choose the same.
  27. #21
    Jax Beach, FL
    I just wanted to show that there some connectors out there made for that type of thing, while poking a bit of fun. Some guys wouldn't know that some of these things exist.
