Thanks Thanks:  3
Results 1 to 9 of 9
Thread: 10R80 Auto Trans
    Jan 2018
    10R80 Auto Trans
    Hey Guys. Planning my build and was wondering if anyone has used the 10r80 auto from a 2018 Mustang. I'm 6'2 with big clunker feet so I'm worried about the room in the foot box. FFR recommends auto trans for big guys so as I am doing some research, that seems like an awesome trans to strap to a 5.0 Coyote, but not sure if it will fit.
    Senior Member JOP33's Avatar
    Haslet, Texas
    You may want to reach out to Don Shapansky. Don got me started on my build. He built a 33 with a Coyote and AODE 4R70W. Now it was a Gen I and I believe FFR has made some changes to help with spacing. Don was extremely helpful. Here is a link to his album and you can PM him through the forum...https://thefactoryfiveforum.com/album.php?albumid=787
    HTH
    JOP
  3. Thanks eaglecook thanked for this post
    Colorado Springs
    The 6R80 won't fit without some subtle changes to the trans tunnel. I would guess that with 4 more gears, the case will be considerably bigger. But I have not been able to find any dimensions for the 10R80.
    .boB "Iron Man"
    www.RacingTheExocet.com
  5. Thanks eaglecook thanked for this post
  6. #4
    Simi Valley, CA
    Svtfreak and I are using 6R80 automatics and they barely fit in the stock trans tunnel. I understand that the 10R80 has a larger case (although I don't have dimensions to prove it), and probably will not fit without major mods. The foot box is small enough as is, and the shift lever sits higher than some folks would find comfortable. So, my guess is that a 10R80 could be shoehorned into a Hot Rod, but would cause so many other problems as to not be worth the effort. My recommendation is to get a 6R80 or 4R70 from one of the reputable aftermarket vendors.
    HTH, Keith HR #894
    Just thought of another issue: FFR does not support any of these transmission options, so you will have to get a custom driveshaft built. Not a big deal, just something to remember to put on the build list.
  7. Thanks eaglecook thanked for this post
  8. #5
    Prairieville, Louisiana
    Keith speaks the truth. The 6r80 fits but it’s tight. Any longer or larger diameter would cause more troubles than is easily fixable. Longer or wider at the back will result in hitting the frame. Anywhere in the middle will mean making the tunnel larger than it comes from ffr. I’m sure it’s doable but how much work are you willing to do?
    Honestly, the 10 is a 4.69 first gear. The 6 is 4.1x. The hot rod is so light already, that low of a first gear will be very touchy. The 6r80’s is touchy also but workable with taller tire and rear gear. And I’m having the tuner make it not go to 1st unless dead stopped. If any mph, it’ll stay in 3rd. The close ratio is great for getting good mileage in a 4000 lb car but it’s gonna be a bit quirky in a 2300 lb car. But, if you do it, it sure will be freakin cool.
    '33 Hot Rod
    MK4 Roadster
  9. #6
    Jul 2019
    Anchorage, AK
    I’m trying to shoehorn a 6r80 in my hot rod frame now. Any suggestions on the modifications to the frame behind the trans tunnel that I need to make? I don’t think I can get the transmission far enough back and down to fit without some metal removed.7E95BD29-55FF-49C8-B6E0-9C958F924777.jpg
    FFR Hot Rod Truck #79
    Gen III Coyote with 6R80 A/T
  10. #7
    Jan 2018
    Yea, I'm having trouble finding dimensions for it as well. Sure don't want to loose space in the footbox as that is the entire reason for going with the auto trans. Thanks for the info.
  11. #8
    Jan 2018
    Quote Originally Posted by Svtfreak View Post
    HaHa,.. part of me wants to do it just for that cool factor! :-) I've still got some time to decide (now that FFR is backed up months, even MORE time...). So I'll continue the research on the size, but your points about the twitchiness are solid. Thanks. I may just end up going manual as that is my preference. What kind of room do you have in your footbox with the 6 in there?
  12. #9
    Quote Originally Posted by eaglecook View Post
    It’s kind of tight but not bad. Not having the 3rd pedal makes it live able. But there’s not much room for the second foot. I plan on running a clutch pedal sized pad to help with room. Even then, the left foot may find itself no place to hand out down there. To get an idea, I did not narrow the tunnel at all. Mr Bob did make a relief in his and moved his gas pedal over slightly. I haven’t looked at that yet. My next task is to move pedals around a bit, and maybe even build a whole custom brake pedal arm.
    Quote Originally Posted by Alaskan View Post
    Alaskan, if you see my thread “a prototype 6r80 mount”, it details lots of things. I show how I built my mount. Basically, the motor was close to right with the trans sitting on the factory mounts welded to the frame. I needed it dropped ever so slightly to get the right angle. So I cut them off, and built my own trans cross member and mount. It wasn’t hard, as long as you can cut steel and weld. I detailed a few things that are 6r80 related and still adding as I progress, to that thread.
    '33 Hot Rod
    MK4 Roadster
