My front lower control arms are on back order, so I started with the upper control arms, and I also assembled the front brake calipers and shocks:
Please let me know if anyone sees anything wrong with my assemblies so far.
Your work is looking great... Welcome to the fun. On your upper control arms (if you are going with power steering) you will want to do a small modification so that you will be able to get the correct alignment caster numbers. CV2065 (Chad) outlined this modification pretty good in his build thread. Here is a LINK to his page and information on this modification.
Again, welcome and enjoy the build...
