Don’t cut off the headlight switch connector, Look at the headlight switch that was provided and the connector you described. They go together.
Not sure about the auto meter gauges wiring.
Based on your setup there will likely be some wires that are not utilized.
Figured part of this out- I am missing the headlight switch- checked the parts catalog and it is not available. Any suggestions?
