1/4 scoop block off windows, door weather stripping and gauge calibration
As there is a lot of wind noise coming from the 1/4 scoops I decided to make the block of windows. I would’ve ordered RT’s set but my driver to passenger side is different so had to make it custom per side.
Bought some Lexan and aluminum angle at HD and started engineering the solution. Made a cardboard template for the opening and transferred that to the Lexan. Then spray painted a black border just as I had done with the scoops. Made the vertical pillar and then the inside rail. That was more complicated due to the compound curves. Made a series of releaf cuts on the front and back end. That allowed to bend a downward curve but also manipulate the edges up or down.
After spray paint I covered it with door stripping, as well as the pillar piece.
Both pieces clamp the Lexan in place and it looks pretty good.
I also put some weather stripping on the door and door opening. Self stick D stripping on the back end of the door and along the sill. On the front of the door I put D stripping on the body and the door to bridge the gap.
Between the two it helps reducing the wind and exhaust noise a bit.
The other day I used Google to mark off 2miles on the main road near my house. I then drove it with my DD to double check. That’s really accurate. So today I put the Speedo ( No not my European bathing suit) in calibration mode and drove the trajectory. When parked I pushed the button at which point the calibration was done. Up to that point I had been driving with a speed app on my phone, so that now worked as a systems check. It was dead on. Then drove to the gas station and calibrated my fuel gauge. Put in 2 Gal for empty and then filled it up.
I guess it’s true what they say about filling up and people coming to talk to you.....
Keep on checking stuff off the list.
nicely done. The Gen 2 window is different from the Gen 3 I have, but the end result is the same.
David W
Mkll 4874 built in 2004
Originally Posted by
John Dol
thanks for the input was that the seals that ffr sent with kit?
