Okay... question #1 With my upper steering shaft mounted through the upper mount on the frame it does not come through the center of the hole in the dash. It is so off center that it rubs the inboard side of the hole and that is with the upper mount pulled outboard as far as possible. If I move the mount over the width of the bolt hole it centers pretty well.
question #2 To use the Wilwood remote master cylinders where is the best place to mount the reservoir? It looks like most of the reservoir can be mounted above the master cylinders but my feed line is below the master cylinders...is that okay? My master cylinders are reverse mount and are located inside the foot box.
I'm not exactly new to this stuff but with the talent I have seen on the forum I would appreciate some suggestions.
Thanks...again.
