Last Chance Auto Restore
Thanks Thanks:  11
Likes Likes:  6
Results 1 to 27 of 27
Thread: My T5 is crooked
    Senior Member NA5KAR's Avatar
    Jun 2018
    Coral Springs, FL
    My T5 is crooked
    Hi guys. I'm really just looking for corroboration here. I received my Blueprint engine / transmission this morning. I'm a couple weeks away from being ready to put it in the car. I went with the 302 with a Holly Sniper and a T5 transmission. Within minutes of its arrival, I had the crate walls removed. Blueprint does a nice job of protecting and packaging the drivetrain. So, as I inspected everything about my new toy, I noticed that the T5 is about 8 degrees rotated towards the drivers side. Meaning that the shift bracket does not sit perfectly vertical. Where it mounts to the bell housing, the passenger side is much higher than the drivers side. I'm an OCD guy, so I noticed it right away. I spoke to Johnny from Blueprint and he asked me to email him pictures. He got back to me quickly and said that it's normal. I do trust him, but I guess I'm looking for anybody who has experienced this or has first hand knowledge. Thanks in advance for any comments. FYI, the yellow line in the picture is my addition with photoshop.
    Gordon Levy's Avatar
    Maricopa AZ
    normal
    Go Fast Part and tech Specialist gordon@levyracing.com
    http://www.facebook.com/levyracing www.lrclassicsllc.com
    Completed over 230 FFR builds in the last 25 years and still counting
    Dublin, OH
    Ha! I'm dealing with the exact same thing. I assumed it was because I hadn't trimmed the mounting tab on the PS just in front of the shifter (in your pic, the zip tie is through it). This tab might cause clearance issues with your e brake mount. I'm in the process of trying to trim this off with the trans already installed. I'll let you know if this fixes my tilt to the DS and also check my own bellhousing.
  4. Thanks NA5KAR thanked for this post
    As Gordon said, totally normal. Had a T5 in my #5125 build. These pictures show (1) it's rotated off to the LH side as you're finding, (2) if you zoom in on the second picture where the T5 mounts to the bell housing, shows the same as yours. I didn't remember exactly, but in the second picture you can also see I apparently trimmed back the tab on the side of the transmission to clear the e-brake. Other than that, the T5 fits easily. It's small compared to its TKO big brother which also fits.
    Build 3: Mk4 Roadster 20th Anniversary #8674. Sold 09/07/2020. Build Thread and Video. Build 4: Gen 3 Type 65 Coupe #59. Gen 3 crate Coyote. Legal 03/04/2020. Build Thread and Video
    Build 5: 35 Hot Rod Truck #138. LS3 and 4L65E auto. Rcvd 01/05/2021. Build Thread
  6. Thanks NA5KAR thanked for this post
  7. #5
    Dublin, OH
    Quote Originally Posted by NA5KAR View Post
    just checked my T5, and this is the exact issue i'm experiencing. at first, i assumed it was the tab interefering w/ the ebrake mount. after closer inspection, there doesn't appear to be any contact between the tab and the mount. my trans to bellhousing is also a bit angled, leaving the top of my shifter plate to lean a few degrees to my DS. I was worried i'd need to pull the trans out to cut off this stupid tab. thanks for posting. very timely!
  8. Thanks NA5KAR thanked for this post
  9. #6
    The angle is even worse on T-5's used in the 3rd generation Camaros from 1982-1991.
    Check out this jewel of a bellhousing to see it leaned even further to the left:
    https://www.ebay.com/p/659547843
  10. Thanks NA5KAR thanked for this post
  11. #7
    Perkasie, PA
    normal
    Why is the T5 rotated from level? Does the mount to the chassis need to be shimmed to compensate? Is the lube level affected? Being a plumb, level, and squared away kind of guy, that would drive me nuts.
  12. #8
    Tybee Island, GA
    NA5KAR, this would probably be the right time to notify you (If you weren't aware) that when you install the engine transmission combo, it's also normal that they'll be off center a little toward the passenger side of the car. Designed to be like that to offset the weight of the driver (I had asked the question when installing mine a few years ago).
    You're doing great and congrats on the combo from Blue Print
    (Since you're in Coral Springs; did you see Nascar is allowing spectators for the Homestead Race?)
    Videos are at: YouTube Videos
  13. Thanks NA5KAR thanked for this post
  14. #9
    Jun 2018
    Coral Springs, FL
    Quote Originally Posted by DadofThree View Post
    Thanks Dave. I was aware of the PS offset. My OCD will allow that. I haven't been to a Nascar race in years. Would enjoy going, but lost interest years ago when I realized that the drivers were a bunch of rich cry babies. Thanks for the heads up.
  15. Likes Railroad liked this post
  16. #10
    Jun 2018
    Coral Springs, FL
    Quote Originally Posted by egchewy79 View Post
    Thanks for the comments. I don't know what the effect will be on the e-brake, but I imagine it will be fine. I've received several confirmations that the tilt is normal. I'll consider it normal. Thanks
  17. #11
    Jun 2018
    Coral Springs, FL
    Thanks so much for the confirmation. It caught my eye immediately when I unpacked the crate. I feel much better that it happened to others. On another note, I love your threads. They have been like a bible for me as I slowly move forward. Thanks for the help.
  18. Thanks edwardb thanked for this post
  19. #12
    Jun 2018
    Coral Springs, FL
    Glad I'm not alone in this issue. From the responses I've received, and the Google stuff I've read, this is normal. I'm interested in the results of your fitment issue. Thanks again.
  20. #13
    BluePrintEngines's Avatar
    Nov 2015
    Kearney, NE
    Glad everything is confirmed and we're all set.
    Check out our crate engine offerings at www.factoryfiveengines.com
    Give us a call at 1.800.483.4263
  21. Thanks NA5KAR thanked for this post
    Likes NA5KAR liked this post
  22. #14
    Ford made it that way on purpose. And in case you didn’t already know, don’t be alarmed when you notice that the engine is not centered in the chassis...Factory Five did that on purpose too
  23. Likes Erik W. Treves liked this post
  24. #15
    Jun 2018
    Coral Springs, FL
    Thanks Jeff. I'm good with the offset.
  25. #16
    Dublin, OH
    to make it easier, trim that tab off anyway. mine is clear of the ebrake mount, but it might make it easier to insert the drivetrain. I did the pulley modification of the ebrake as described by edwardb and was worried about the PS bias of the transmission getting in the way. there's room, but it's tight once the trans is in. if you plan on doing this mod, do it before you insert the drivetrain.
  26. Thanks NA5KAR thanked for this post
  27. #17
    Jax Beach, FL
    Wait until you put the engine in and find it doesn't sit level. Cobras and rulers are not a good combination.
  28. Thanks NA5KAR thanked for this post
  29. #18
    Edmonton Alberta
    right wait until you see the body the right and left are not the same.
    David W
    Mkll 4874 built in 2004
  30. Thanks NA5KAR thanked for this post
  31. #19
    Tybee Island, GA
    But in all of this imperfection, don't sweat it! Nobody will notice but you. They're stunning and a ton of fun, even with their flaws! (pic CSX 3102)
  32. #20
    Nov 2018
    Centennial, CO
    Quote Originally Posted by David Williamson View Post
    David W
    What a relief! I thought I was the only one.
    POM - July 2020
    Graduation thread
  33. #21
    Jun 2018
    Coral Springs, FL
    Love that pic! You're right ... I'm the only one who will see it. I'm 100% ok with it. Just wanted to see if anyone else noticed this. Thanks
  34. #22
    Jun 2018
    Coral Springs, FL
    that's the reason I started the post. Johnny from Blueprint was awesome when I asked him about it. He got verification from his techs and from FFR. I was satisfied with his answer. I only wanted to see if others had the same experience.
  35. #23
    O'Fallon, MO
    What did you expect, that is how it was designed?
    Mrk III, 331 stroker, Borla stack injection, T5, 3:55 IRS, Power steering and brakes. Kleiner body & paint
  36. #24
    Jax Beach, FL
    I remember freaking out when I saw how crooked the hood opening was. The forum set me straight......well, set me crooked.
  37. #25
    Quote Originally Posted by walt mckenna View Post
    The Mounts line up vertically. When I was building ol' 5369 and saw how it went together I figured, "Huh. Leaning toward the driver... cool". The trans mount fit so I really didn't think about it again until this thread.
  38. #26
    Apr 2020
    Is the TKO 600 rotated the same way?
  39. #27
    Senior Member RoadRacer's Avatar
    Quote Originally Posted by Joe D View Post
    No, it sits level
    FFR33 #997 (Gen1 chassis, Gen2 body), delivered 4/17, driving 2/21! build thread
    My build: 350SBC, TKO600, hardtop, no fenders/hood, 32 grill, 3 link w/brace & sway bar, GT500 wheels
    Previous cars: GTD40, Cobra, tubeframe 37 Ford, 55 Chevy, 66 Nova, 56 F100
  40. Thanks Joe D thanked for this post
