0
0
Originally Posted by
michael everson
That bundle of wires is for the wipers. The jumper wires they reference are part of the dash harness which is part of the Ron Francis wiring harness.
Thanks, Mike. Will take another look at that. Glad to know those are for the wipers since i'll be installing those eventually.
MKIV Complete Kit #9494 l Delivered 1/5/19 l First Start
11/28/20 l First Go-kart
4/11/21 l Carb'd 347 l Mid-shift TKO600 l 3.55 IRS l P/S l Forte Mechanical Throttle Linkage l RT Turn Signal, Drop Trunk l Breeze Upper/Lower Radiator Support, Fan Shroud l Boig Upper/Lower Cool Tubes & Quiet Pipes l 18" FFR Gasser Wheels l
