0
0
Question for Users of the Autometer Ultra-lite Gauges
First step in the instructions is to connect "the gauge light power wire from the oil temp gauge with one of the small white jumper wires." I'm not seeing any small white jumper wires in the kit unless I'm to use the white wire from the Four Conductor Multicolor Wire (part #13161; Box 22) - can someone confirm? I didn't see any other reference to using this bundle of wires in the instructions, so I feel like it's the right path. Thanks in advance!
MKIV Complete Kit #9494 l Delivered 1/5/19 l First Start
11/28/20 l First Go-kart
4/11/21 l Carb'd 347 l Mid-shift TKO600 l 3.55 IRS l P/S l Forte Mechanical Throttle Linkage l RT Turn Signal, Drop Trunk l Breeze Upper/Lower Radiator Support, Fan Shroud l Boig Upper/Lower Cool Tubes & Quiet Pipes l 18" FFR Gasser Wheels l
