Originally Posted by
VRaptor SpeedWorks, LLC
While it might be possible, honestly, it's not realistic for 99.9% of the population. Unless you're lucky enough to find and buy a donor car locallly for an unbelievable low price that has every single item you need intact (including wheels & tires), and are able to sell off the unused parts for top dollar so that you make a significant profit off the donor......and buy a cheap used transaxle and clutch (and use both as-is)......and you do all of the body and paint yourself using very cheap paint and either don't use a paint booth, or have a friend that owns a body shop that will let you use his for free (and also lets you use all of the masking tape and paper you need for free)......no heat or AC option.....live next door to FFR so you don't have to pay for gas to pick it up or have a delivery fee.....do not use any heat or sound insulation at all.....have free access to all of the nuts, bolts, wire loom, heat shrink, solder, fluids, adhesives (windshield, carpet, suede, headliner, mesh install) you need......
Realistically now, consider this. If I order up a GTM kit with AC option, that is $20k kit + $1350 AC option + $1300 delivery = $22650. $30k - $22650 = $7350. That $7350 is your entire budget to buy transaxle, clutch, CV's Starter, engine oil, trans fluid, coolant, brake fluid, windshield adhesive, windshield primer, spray adhesive for carpet & suede, contact adhesive, silicone, wire loom, heat shrink, connectors/terminal ends, solder, electrical tape, nuts, bolts, rivets, washers, body filler, lacquer thinner, wax & grease remover, paint filters, sand paper, masking tape, masking paper, primer, sealer, paint, clear coat, zip ties, R134a & PAG oil if you're using AC, hose clamps, drill bits, etc, etc, etc.
Might sound like nickels and dimes until you actually pull out your wallet and have to buy all this stuff. By the time you buy the windshield primer and adhesive, you'll be out about $80. Buy enough spray adhesive to do all of the carpet, suede and headliner and you'll be out another $100 at minimum. Last I checked, a gallon of good clear-coat was over $400. I just received my order yesterday from McMaster Carr for absolutely nothing but bolts, washers and rivets. $180. The materials (no labor) for the last paint job (everything from masking tape & sandpaper to clear-coat) was $2400. Can you see that $7350 evaporating yet?
