Thread: Dash fitup
    Dec 2019
    Dash fitup
    This is probably due to my inexperience, but it appears I neeed to modify the corners of the dash to fit around the roll cage.
    If so, any tips to help along the way. I was planning on many mini cuts until it fit.
    Any pictures would be very helpful. This is one area where manual does not show anything.
    Thank you
    Aug 2019
    Alvin, Texas
    Haven't done mine yet....but I know a bit about fabrication.
    Make you a cardboard template of the dash....and cut it up first.
    Aug 2019
    Arlington, WA
    I too have not yet installed the dash. But I see in appendix A of the build manual there is a template to assist in the cut-out for the steering column, but nothing for the roll bar cut-outs. Pretty typical of the manual, they mostly appear to be written for the gen 1's and I think the full cage was begun with the gen 2.
    FFR Gen 2 35 truck, Barrett Jackson edition # 4, chassis # 81, 525HP LS3 & 4L75E, 8.8" 3 link.
    Aug 2019
    Fort Lauderdale
    Templates make sense: I made a mess of mine with a couple of careless cuts. The template for the steering worked for me, once I figured out where to apply it
    Dec 2019
    Thank you, I have a lot of cardboard from broken down boxes from FFR
    Jun 2019
    Whitehouse TX
    Something that we purchased was a Dremel 4300. It makes the fiberglass cuts and massaging the hole sizes much easier than air grinder. Easier to handle
    Aug 2019
    Fort Lauderdale
    dreamed, edge grinder, step drill bit have all been used extensively in my build. The step drill is really important (as I have learned) to keep a hole from "walking " when enlarging a pilot hole
    Senior Member Pat Landymore's Avatar
    Dec 2018
    SW Calgary, AB
    Nice work, it looks like an excellent fit!
    Senior Member Robodent's Avatar
    Aug 2018
    Hampshire, IL
    Looks good, I used a rubber bubble gasket 3/8 “. To finish off the front edge where it meets up by the windshield. Think I got it from McMaster and Carr . Rob
    FFR 35 p/u # 0016 Dart 347 TKO 600
