Results 1 to 8 of 8
Thread: Pedal Bender
    Senior Member Jim Wehr's Avatar
    Hamilton, VA
    Pedal Bender
    Does anyone have one that I can borrow? Will pay shipping both ways.
    Jan 2020
    What are you looking for?
    2020 Mark 4, Coyote 5.0, gen 3, complete kit, solid rear. Started 3/22/20
    Hamilton, VA
    Quote Originally Posted by Mike Garrett View Post
    Pedal bender. It is a tool that was used to bend the stock brake and clutch pedal arms to provide more foot room. Someone on the other forum machined 10 of them and we used to pass them around the group gratis. I need to change the angle on mine.
    Colorado Springs
    I bought one of those 10. I used it on my Exocet, and then lent it out. Haven't seen it since.
    .boB "Iron Man"
    www.RacingTheExocet.com
    Sacramento CA
    I saw posts with pictures - cant find them now! Here is two reference links
    https://thefactoryfiveforum.com/show...S-Pedal-Bender
    https://www.ffcars.com/threads/pedal...anyone.515009/
    Any pictures of the bender would be appreciated!
    Hamilton, VA
    Quote Originally Posted by Bob Cowan View Post
    Yep. I mailed mine on to the next guy back 12 years ago. Haven't seen another since...........but someone has one for sure!
    JohnK's Avatar
    Sep 2018
    SF Bay Area, CA
    I don't know if this helps anyone, but I found this thread with a CAD drawing of the pedal bender on the other forum. I think anyone with a mill could make one pretty easily. I've been toying with the idea of buying a bench top mill for a while. If I had one, I'd make a few of these just for practice and fun.
    https://www.ffcars.com/threads/pedal-bender.266971/
    It would seem from reading over the posts on the links, Just Puttering posted, that MrMustang would be the fellow to contact, re the bender.
    I don't think they are in circulation quite as much as they were at one time, since the Wilwood pedal system has come into play, but they are great for anyone still using the donor pedal set up.
