12
21
rthomas98
Quick question as I have noticed a few people doing this on the brake lines; is there a reason for the "corkscrew" effect as opposed to cutting and re-flaring. Noticed a few people doing this now and I am about to start the brake lines myself.
rthomas98 - as BadAsp427 noted, I coiled my lines because I didn't want to cut them and re-flare them. It's not difficult but does require a bit of patience(doesn't each area require that?) One helpful tip would be to try to practice on a wire hanger or an extra piece of hard line if you have it. I also used the wire hanger to trace out the path I wanted before working with the hard lines. Good luck and keep us posted on your progress!
Mark IV Complete kit delivered 7/7/20
Blueprint 427 ordered 11/23/20
