Any words of wisdom regarding quick release steering hubs? Does anyone make one that will fit the coupe without needing a blacksmith shop to attach it?
We make a bolt on! For the wheel that is. It still needs to be welded to the shaft [he a bad mutha - shut your mouth - I'm jus talkin bout Shaft]
Forte's Parts Connection: Your Solution Specialist! Motor & Transmission Packages Starting @ $8200.00 Call To Order 508-875-0016
Paht time parts guy!!!!!!!
Yes but they are not cheap. :-) I just did a setup using my turn signal system that uses a trick release system incorperated in the steering wheel hub itself. Basicly it bolts on top of my setup using the standard ffr hub that I drill for the differant wheel pattern. It's not cheap but pretty neat in design.
