Results 1 to 8 of 8
Thread: Alternative friction modifier IRS
    Jun 2017
    Norway
    I drained the IRS diff since I needed to exchange the pinion flange. I went to the local ford dealer, and they couldn't get me the XL-3 friction modifier. Can I use any friction modifier out there, or alternatively an oil with limited slip friction modifier already added?
    Senior Member Hacksaw84's Avatar
    Jun 2017
    Couldn't get it? That is strange, ordered mine off Amazon. Came 2 days later. I could smell it coming down the street.
    https://www.amazon.com/Ford-XL-3-Fri.../dp/B000NU5LP6
    Michael aka @my_cobra_build on Instagram
    Base MK IV Roadster with several options. Body is Lamborghini Grigio Lynx w/ Audi Vesuvius Gray stripes. 25th Anniversary FFR wheels. Seats and interior by Intatrim.
    Gen1 Coyote w/ Comp Cams & Cobrajet manifold. Tremec TKO 600 w/ a midshift kit. 2015 IRS w/ 3.73 Torsen diff. FFR Headers, Gas N Pipes, Power steering & power brakes.
  3. Likes Badfish liked this post
    Jun 2017
    Norway
    Yeah, I'm in Norway. Got a feeling they won't ship that stuff here. Anyway, would be a lot easier for me to find a good alternative locally.
    Jun 2017
    Quote Originally Posted by Oystein View Post
    Well that makes a LOT more sense. Ha
    In that case I would just get the oil with modifier in it. It doesn't have to be Ford.
    Jun 2017
    Norway
    Just what I needed to hear. Thank you Rich!
    Sacramento CA
    The additive helps to keep the clutches from popping when turning corners. If it does this after some time to get the oil,and additive mixed, you will know it is not working. I think you will be fine as stated below!
    Jun 2017
    Norway
    Quote Originally Posted by Just puttering View Post
    Thank you, very good info!
