Anyone know where i can find some gen 1 SBC valve covers with 427 logo on them? I can find everything but....
If you can't find what you're looking for, there are companies out there that will engrave valve covers to your specifications. Here's just a few:
https://www.ansenvalvecovers.com/col...e-valve-covers
https://undercoverinnovations.com/pr...-valve-covers/
http://www.advancedautographics.com/
I thought about putting these on Redbone, but then decided against it.
https://yourcovers.com/valve_cover_i...-6_pol_lg2.jpg
I didn't want Zora Arkus-Duntov to start spinning in his grave so I passed on them.
That ain't gonna be easy....
