It seems that it needs fenders but I see a lot of Hot Rods without? Is there any way around this?
I'd start here: http://www.bipac.net/page.asp?conten...olbox&g=SEMAGA and see what it says about North Dakota requirements. Also, check the ND State web site for it's vehicle code to see what equipment is required.
Ray
I couldn't get to this page, but here's the map I used when I was looking into it. You can click on any state and see the laws:
https://www.semasan.com/resources/ev...-all-50-states
Curious about the same thing in ND for a 35 truck. Hoping to be able to get around the issue. Plenty of hotrods running around without fenders. If anything I was going to make some cheapo bike style fenders to put on during inspection and remove after inspection. I guess risk getting a ticket. Where u located Mike?
I would imaging ND is going to be fairly simple like SD was for me (not a lot of rules) but I'm not sure.
Jim
