4-link, Upper control arm bolts.
I have a problem and wondered how everyone else using the 4-link mustang rear suspension has delt with it. with the aluminum panels installed the upper control arm bolt wont go in because on one side is the aluminum panel and the other side is a frame brace. I really don't want to put holes in the aluminum panel (or remove my interior when I need to take this bolt out) but the only options I can see is to cut holes in the aluminum panel or cut the frame brace and move it (don't really want to do that either, frame is powder coated). I can get some actual pictures of it tonight.
I was just discussing this with a customer this week. Don't have a solution for you but don't see any reason this would need to be removed. At least not for a long time. I would install them from the inside out so that if you do need to remove, the aluminum will be easier to cut than the frame.
