0
10
Sounds like a very nice combination because we all know that a good set of heads really will make or break any engine's power output...For my set up I was hoping to make between 383-400 ponies and we easily bested those numbers because of the head, came and intake that I'm running so I'm sure you will too.
We pulled well over 450 with the timing set at 10 initial maxing at 30-31 total...Bumping the timing to 13 initial 33-34 total pushed the HP number up to 495-497...Our specs are similar from compression, cam, and intake perspective, but I've got a couple of extra cubes...With that said I think you'll be making between 425-475 depending on how high you spin the sucker...Like you, I'm not pushing the RPM's over the moon so I won't push the rev-limiter much past 6,000 RPM even though it kept pulling up to 6,500.
My suggestion would be to get NAZ to run your numbers because he nailed mine within 5% compared to the actual dyno...He's got a heck of a system that he uses.
Welcome Aboard & Welcome To The Family!
