If anyone has installed the bolt on sway bar on the COUPE (or even the weld on bracket kit), were you able to get the rearward hole in the radiator support bracket? Mine has no room for either the bolt head or a washer/nut due to the horizontal flange on the outside lower side.
Thanks!
Eric
