Results 1 to 3 of 3
Thread: Coyote Oil Pick up Torques
    Huntsville, AL
    Are these the correct Coyote oil pick up torques?:
    Oil pump pick up tube to pump 89 + 45 deg. lb.-ins (2-10mm screws)
    Pick up tube strap to main cap 19 lb.-ins
    Pick up tube spacer to main cap 19lb.-ins
    Here is the data from Ford Racing Performance M-6007-A50NA 5.0L Engine (page 8 of 11)
    Pick up tube strap to main cap 25Nm 19Lbs-in
    Pick up tube spacer to main cap 25Nm 19Lbs-in
    25Nm is equal to 221Lbs-in
    Is this a typo in the FPR data or am I missing something.
    Last edited by 4.6 litre; 10-30-2020 at 02:15 PM. Reason: M-6007-A50NA Engine Data
    Senior Member Hacksaw84's Avatar
    Jun 2017
    Michael aka @my_cobra_build on Instagram
    Base MK IV Roadster with several options. Body is Lamborghini Grigio Lynx w/ Audi Vesuvius Gray stripes. 25th Anniversary FFR wheels. Seats and interior by Intatrim.
    Gen1 Coyote w/ Comp Cams & Cobrajet manifold. Tremec TKO 600 w/ a midshift kit. 2015 IRS w/ 3.73 Torsen diff. FFR Headers, Gas N Pipes, Power steering & power brakes.
    Quote Originally Posted by 4.6 litre View Post
    I think the 19 in lbs SHOULD READ 19 FT LBS.
    If you multiply the 19 X 12 it is 228, which is about what they are showing for equivalent to 25 Nmeters 221 in lbs.
    If you have not removed the fastners currently on the pickup tube, use your tq wrench and see what they break loose at.
