[QUOTE=Jeff Kleiner;523788]I've seen a Godzilla Backdraft in person. The pan hangs 2 inches below the frame rails leaving it less than 3" above the ground with no protection. Remember, the pan houses all of the components and controls for the variable displacement oil pump.
Thinking of the after market 4x4 shops. I'm no expert, but wouldn't someone consider a frame mounted skid plate vs a low oil pan with no protection? Just a thought.
