0
0
Ride Height Education
Hey Guys
I need a little education on the ride height, or maybe I'm just missing something obvious
I'm using the lower holes since I'm running the fenders / running boards so it says Front is 5.5" & rear is 6" and to measure from the ground to the bottom of the frame.
My confusion is what part of the frame do I measure? Especially for the front since the frame angles up to the suspension? In my pics, do I measure where I have the red circle for front and rear in the first pic, or for the front do I measure on the frame rail that I have the arrow in the 2nd pic?
Also, is there a pretty straight forward procedure for doing this? Thanks in advance
Seasoned Citizen
The points you circled are the points I use. You can purchase a variety of ride height measuring tools to make this job easier at the track but when setting mine on my four-post lift I use a machinist's scale and a long level (for a straight edge, my lift is already level). The level sits across the two ramps making it easier to split hairs on the measurement by using the top edge of the level to read the scale. Remember when making an adjustment on your coilovers you should jack up the car to unload the spring before turning the adjuster to prevent thread damage (use anti-sieze on the threads). Then roll the car forward and aft a few feet to settle the suspension before measuring again.
33 Hot Rod Super Pro Drag Racer Build:
33 HR NHRA Cert Roll Cage Build
The first pic is spot on.
FFR33 #997 (Gen1 chassis, Gen2 body), license plate DRIVE IT says it all!
build thread
Originally Posted by
NAZ
Cool...Thanks Naz.....yeah my 4 post lift is level too so it's a good starting point..... Jim
RoadRacer
cool...Thanks
