Results 1 to 5 of 5
Thread: Max tire size Full Fender rear. 33 Bicycle Front Fender
    Aug 2020
    Folks can someone help please,
    I think 255/45R18 with 30 offset and 3/4: spacer works well in the front, please correct me if I'm wrong..
    but for the back I'm perplexed....anyone running a 285?295?305? if so what is your setup?
    Seasoned Citizen NAZ's Avatar
    If they are the same fenders & brackets as the hot rod, 255/35ZR18 fit but needed 1/2" spacers to center on 18"x9.0" wheels with 5.0" back spacing.
    Mar 2020
    Huntington Beach, CA
    Rear tire size
    Quote Originally Posted by Bakers35 View Post
    My rear tire size is 285/40-R18. I am running Nitto NT555G2 tires on Rocket Racing Hypershot wheels 18x11 with 7.00 inches backspacing. It is a snug fit, but works with full fenders.
    Mar 2020
    BTW, the wheel width is important for these wide rear tires. If I ran a narrower rear wheel, the vertical sidewalls would reduce fender clearance.
    Aug 2020
    Thank you that's exactly what I hope to run, thankyou for the reply.. Cheers
